Ir para o conteúdo principal
The Portege Z830-S8302 is a laptop manufactured by Toshiba and was released late 2012. This Ultrabook is thin, sleek, and lightweight making it easily portable.
5 Perguntas Visualizar todos
hdmi port not working
hdmi port not function to conect with other mirror
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @salumkarume
Just verifying the you're pressing the Fn+F5 keys (both together) to direct the display from the laptop screen to the external monitor?
Here's what the user manual states:
While holding down Fn, press F5 repeatedly until the setting you want takes effect. Briefly pause each time you press the F5 key to allow time for the display to change.
This hot key cycles through the settings in the following order (the last two options are available if an external monitor is connected):
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and external monitor (extended desktop)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Salum Karume será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 12
