Ir para o conteúdo principal
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
How to fix nod displayed pc
My pc screen doesn't show anything
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
When you start the system do you hear the fan and the HDD drive respond?
por
Adicionar um comentário
1 resposta
@chrissrich could be an issue with your LCD or with the motherboard. rule the LCD out first. Connect and external monitor via HDMI cable to your computer. Start your computer and see if that external monitor display properly.
If it does not use the FN+F5 hot keys to make sure that it switches to your external monitor. Should it still not display anything, the issue will be on your motherboard. If the external monitor display properly, tehn the issue is you LCD and it will most likely have to be replaced.
Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chrissrich será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 40
