Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
Model 3 but the factory battery is from model 2
I ordered the model 3 kit, but when I opened my watch, the battery is not the same. I looked at the box, yes I kept it, and it is model 3. However, the battery that the watch has is the A1760.
Has anyone seen this before?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@carlost24430 if your watch has the A1760 battery then your watch is (or at least needs) a Apple Watch 2 (battery). If they shipped you a A1760 then you will have to have the seller repalce it with the proper one for your watch.
Again, if the A1760 is in your watch, it is a Apple Watch 2
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for the response. Indeed, I see the problem, though it is too late to return. Ugh.. I ended up buying the battery for the 2, and it should work.
Thank you for your help.
por
Pergunta mais útil
Where did you buy the battery? Are you sure the watch is a model 3. Are you confusing the Battery ID with the Watch as A1760 is not a Watch ID. Review this listing EveryMac - Apple Watch specs
Pontuação 1
1 comentário:
Thank you for the response. I looked again, and I see the problem, though it is too late to return. Ugh.. I ended up buying the battery for the 2, and it should work.
Thank you for your response.
por
Adicionar a sua resposta
Carlos T. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 103
