Led bulb 120wt repair
Led light bulb 💡 repair
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adicionar imagens a uma pergunta já existente
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Guia
Moderada
30 minutes
Guia
Moderada
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 628
Charging LED bulb repair
por Satya Narayan sahoo
Yes my led bulb is dead
por Ashvini Vaidya
