Ir para o conteúdo principal
A LED bulb 230V is a type of light bulb that uses Light Emitting Diodes (LEDs) as a source of illumination and is designed to operate at a voltage of 230 volts. This type of bulb is commonly used in areas with higher voltage electrical systems, such as in Europe and other parts of the world that use 220-240V AC power.
3 Perguntas Visualizar todos
Led bulb 120wt repair
Led light bulb 💡 repair
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Charging LED bulb repair
por
Yes my led bulb is dead
por
Adicionar um comentário
1 resposta
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adicionar imagens a uma pergunta já existente
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de LED Birne 230V LED
Guia
LED bulb lamp 230V E27 defective repair
Moderada
30 minutes
Guia
Moderada
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hamza Jutt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 628
