Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
Esta é uma boa pergunta?
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
Esta resposta foi útil?
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
Gear Up For Future Repairs
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 88
Ao todo: 1,120
3 comentários
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
por oldturkey03
When I turn it on, it starts in the middle of the mixing cycle.
por Janet Schuroll
por oldturkey03
