Ir para o conteúdo principal
The Sony Bravia KLV-46X200A is a flatscreen TV in Sony's Bravia series.
Can I get the screen pliz
Can i get the screen pliz
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
replacement screens cost nearly as much as a new tv
Esta resposta foi útil?
Pontuação 1
@erickkariuki It will be very difficult to find a new display. Even if it can be found it will most likely cost more than a new TV. You can always do an online search for a replacement but do not search by your TV model alone. Remove the back of your TV and check the label on the back of the LCD. It will have the manufacturer as well as the LCD panel number. Use that for your search. The only other thing you can try is to find the same model as your TV but broken other than the panel. Then harvest the panel from that TV.
Pontuação 1
Adicionar a sua resposta
Erick Kariuki será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 105
