Ir para o conteúdo principal
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
20 Perguntas Visualizar todos
Can I repair problem with power?
Will not turn on with fresh batteries - connections are tight and clean. Power is erratic when adapter is plugged in - the power light comes on and the game plays until just a little jiggle interrupts play then screen goes dark and power light goes out. If I unscrew the back what should I look for?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
katy, check for loose or corroded contacts on your logic board power connector. Try a good cleaning by following this guide Electronics Water Damage. let us know what you find once you open it up, take lots of pictures....:-)
Esta resposta foi útil?
Pontuação 2
Take a look at these guides. They will assist you in getting into the device.
2 of the battery terminals are soldered directly to the main board so check they are OK and not cracked/loose. Also check the socket where the power adapter plugs in (if it is an option) on the main board - again check the solder joints aren't cracked/loose
HIH
Pontuação 1
Adicionar a sua resposta
katy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,237
