Where can I get a new bulb
i have a ledlenser f1 torch the bulb on it has been broken where can i get a new one?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Laurence Ockerse this "flashlight" doesn't use bulbs. It use an LED as a lightsource. This in general are not replaceable but can be repaired. First off there should be a 5 year warranty on this so check to see if you are still covered. If not then you want to tackle the front ring. Use this manual LED Lenser F1 and check around page 16. That should get you to the LED. Post some really good pictures about what you see and post those with your QUESTION. That way we can see what you see and hopefully guide you further through this repair. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 98
1 comentário
Did you try contacting the company?
If you can take the bulb out and take a couple of pics so we can get an idea on its size and base (hint put a ruler in the picture) Adicionar imagens a uma pergunta já existente
por Dan
