Ir para o conteúdo principal
Released in 2017 the ASUS ROG Strix GL503VD is a high performance gaming laptop.
13 Perguntas Visualizar todos
Battery is charged but laptop stops on unplug
Hello,
I have an ASUS GL503VD laptop and I have an issue with the battery.
The BIOS shows that my battery is 91% charged but when I unplug my laptop, it just stops…
The percentage of the battery is always 91% and does not change at all.
What I tried :
  • Factory reset
  • BIOS reset/update
  • Driver reset/update
  • Open the laptop to unplug/plug the battery connector
Can someone help me to solve this please ?
Thank you in advance.
Esta é uma boa pergunta?
Pontuação 2
8 comentários
same issue however i replaced the old battery for a new one but still the same issue
por
What does your bios do if you are looking at it when you unplug the cord?
por
a new battery did not solve it for me
por
@caperry8 it just shutdown instantly
por
@Brian Beckford I don't think that will solve mine either ...
por
Exibir mais 3 comentários
Adicionar um comentário
2 respostas
Pergunta mais útil
@rtxx
Which driver did you reset?
Did you try uninstalling the Microsoft ACPI-Compliant Control Method Battery from Device Manager > Battery and then after it has uninstalled restart the laptop and let Windows "find" and install it again? Also check if it has the latest drivers installed. Right click on the entry and click on Update drivers and follow the prompts.
Create a battery report to check the status of the battery. When you have the report, compare the Design Capacity value versus the Full Charge Capacity value to determine it status. With a good battery they should nearly be the same.
Esta resposta foi útil?
Pontuação 1
6 comentários:
PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
2021-12-20 49 096 mWh 64 448 mWh
2021-12-21 49 096 mWh 64 448 mWh
2021-12-22 49 096 mWh 64 448 mWh
2021-12-23 49 096 mWh 64 448 mWh
2021-12-24 49 096 mWh 64 448 mWh
2021-12-25 49 096 mWh 64 448 mWh
2021-12-26 - -
por
And yes I've already uninstalled Microsoft ACPI-Compliant Control Method Battery and updated it
por
@rtxx
As the laptop stays on when the charger is connected, it appears as though it is a hardware problem on the motherboard, i.e. no power into or out of the battery.
What is the model number of the motherboard? It may be necessary to find the schematics for the motherboard and usually they are easier to find when you know the board number than just the laptop name and model number.
por
The model number is dabklmb28a0
por
@rtxx
Unfortunately I can't find any schematics only boardview links, which doesn't help as they only show the location of components on the motherboard.
Found this link which didn't solve the problem but maybe will give you some ideas of where to look.
It appears that you are not the only one with this problem.
por
Exibir mais 1 comentário
You should consider replacing the battery…
How old is the computer?
Pontuação 0
1 comentário:
The laptop is 3 years old.
I'll buy a new battery this week to try it
por
Adicionar a sua resposta
Rtxx será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 1,354
