Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
How do repair the battery connectors
How do you repair loose battery connector on gba sp
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
shermad32 loose where? If it is loose on the board you will have to look at the motherboard. The battery connector is soldered to it. Double check those solder connections. Use this guide Nintendo Game Boy Advance SP Back Cover Replacement to work on it and you are looking at this connector
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
shermad32 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 772
