Ir para o conteúdo principal
it went into the washing machine!
Goodmorning,
can somebody help me finding out what's wrong with my Ipod. it went into the washing machine and after an hour cycle at 60 degrees it took only an hour to turn on!! amazing...i'm only missing sound, either with headphones and internal speakers. right after it turns on the volume logo appears and lowers the volume to 0 and there is no way to turn it on. tje volume logo appears very often...what part should I replace?
thank you
L.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
luca, the very first thing that I would suggest is that you clean your iPod. The problem that you will run into is corrosion. Use this as a guide Make sure that you clean everything. Replace your battery after you are through cleaning it. At this time, there is no specific part that you need to replace. Cleaning the logic board, the connectors and the cable ends might resolve it. After that, re-evaluate the damage.
Esta resposta foi útil?
Pontuação 0
1 comentário:
And also when electronics get wet, dont turn them on until you are sure that they are dry.
por
Adicionar a sua resposta
luca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 321
