Ir para o conteúdo principal
The Dri-Eaz DefendAir HEPA 500 Air Scrubber model F284 is an air scrubber and negative air machine. The air scrubber uses HEPA filter media.
My Dri-Eaz Defendair 500 wont turn on.
Dri-Eaz Defendair 500 wont turn on. Plug show power, but no noise when I turn on the switch
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @craiggessell ,
Disconnect the power to the machine and then open it up an use an Ohmmeter to check if the 230V AC switch - part #80 has continuity, when operated. (or if you have the 115V AC model, the 115V AC switch - part #73 is OK - (here is the parts list for the 115V model).
If they’re OK then you may have to check the control board for any damage etc. There is no mention of a fuse in either parts list but that doesn’t mean that there isn’t one.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Craig gessell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 332
