Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
D-Pad squeaky when pressed
Lately when I use my GBA SP the D-Pad is slightly squeaky and harder to press. Any ideas on how to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Most of the times it’s caused by the rubber for the buttons. I would order some new rubbers for all the buttons and replace them. BUT, this can also be caused by the actual button(s) soldered on the motherboard. If this is the case, you need to de-solder the broken button(s) and replace it with a new button(s). This can be difficult if you don’t have any soldering experience. Otherwise I would bring it to a repair shop.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Alright, I'll get a triwing and see if I can determine this. I'll update once that happens.
por
Alright :)! Good luck! Looking forward for an update!
por
Adicionar a sua resposta
chefravioli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 16
Duração total: 630
