D-Pad squeaky when pressed
Lately when I use my GBA SP the D-Pad is slightly squeaky and harder to press. Any ideas on how to fix this?
Esta é uma boa pergunta?
Hi!
Most of the times it’s caused by the rubber for the buttons. I would order some new rubbers for all the buttons and replace them. BUT, this can also be caused by the actual button(s) soldered on the motherboard. If this is the case, you need to de-solder the broken button(s) and replace it with a new button(s). This can be difficult if you don’t have any soldering experience. Otherwise I would bring it to a repair shop.
Esta resposta foi útil?
Alright, I'll get a triwing and see if I can determine this. I'll update once that happens.
Alright :)! Good luck! Looking forward for an update!
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 15
Duração total: 630
