Ir para o conteúdo principal
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
turns on and then will not boot up
My Aspire 5251 notebook turns on...then goes to f2 screen says win failed to start a recent hardware or software problem
then goes to a windows loading files screen then after a long time will go to a black screen with mircosft logo and a loading bar then will go to blank screen and will stay there until turned off
please help
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
6 respostas
Solução escolhida
Here is a link to the service manual for your notebook.
http://onlinepdfebook.com/gadget/acer/ac...
Esta resposta foi útil?
Pontuação 2
That sounds like an error with the windows start-up files. Try to start in safe mode (F8 when your computer starts, right after the BIOS check) if that does not help you may have to repair your Windows OS.
Pontuação 2
Hello,
My mothers notebook was having the same problem.I really hope this is not too late, but perhaps this will help people in the future.
1. To boot the computer unplug and remove the battery
2. Then hold the power button to drain the bios- (30 to 60 seconds)
3. Then plug it back in, if it does not boot right away repeat step 2
4. Follow this link http://support.acer.com/us/en/default.as...
5. Find your computers support page and click the "Bios" tab
6. Update your Computers bios to the latest version (for my computer it was 2.14)
7. Restart and it will be fixed... Hopefully
I really hope this helped you. email me at cmullins1995@yahoo.com if you need more help
Pontuação 0
Help I have Acer aspire 5135 and it won't boot up without a disk wit h drivers or the Ethernet cable
Pontuação 0
I did a reset/restore and i held f10
Pontuação 0
I tried numerous things, including reloading the operating system, running check disk and repair. Finally, when I replaced the hard drive, it boots every time and works like a charm. Additionally I replaced it with an SSD, so it boots lightening fast as well
Pontuação 0
Adicionar a sua resposta
annette será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 35
Ao todo: 39,856
