Ir para o conteúdo principal
Repair guides and disassembly information for HP's Envy line of laptops.
The notebook does not charge
When I connect the power plug to recharge the pc does not charge.
Model: Hp Envy 15-ae010nl
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@piero90 check your charger and your charging cable first. Make sure that the output is as written on the power supply. then check the DC-in jack to make sure that it looks ok. If all that looks good you want to consider replacing the battery first. If a new battery does not resolve it consider replacing the DC-in jack and after that you would be looking at the charging circuitry on your motherboard having failed. You can download the service manual for your Envy from here
Esta resposta foi útil?
Pontuação 1
Related Parts and Tools
Shop all
Adicionar a sua resposta
Piero Sabino será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 70
