Ir para o conteúdo principal
Schwinn Mens Tourist 28"/700c Road Bike
How do I remove crank on bike
Ok so I found out my bike has a SR suntour crank and I tried looking up for a way to remove it and I got nothing so con one of y’all tell how to remove it please
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Here’s how to do it:
https://www.youtube.com/watch?v=baa0ghR5...
Esta resposta foi útil?
Pontuação 1
1 comentário:
@mayer its a bike crank not a freewheel
por
kevin remove the chain. Insert one 8-mm wrench into the Suntour crank on the drivetrain side of the cranks. Insert another at 180 degrees on the other side of the cranks. Use opposing force with the two wrenches to loosen the 8-mm hex screws on the cranks. from here
Pontuação 1
4 comentários:
@oldturkey03 That’s what I tried doing but the space to slide the socket or the wrench in is too little
por
To little how? there are deep socket wrenches that have a handle on the side. Possible to use one of those? Any chance you can take a couple of pictures and post those with your QUESTION so that we can evaluate? Adicionar imagens a uma pergunta já existente
por
You got Instagram so I can ft you
por
No. Sorry all I do is iFixit. No social media :-(
por
Adicionar a sua resposta
kevin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 480
