How do I remove crank on bike
Ok so I found out my bike has a SR suntour crank and I tried looking up for a way to remove it and I got nothing so con one of y’all tell how to remove it please
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
kevin remove the chain. Insert one 8-mm wrench into the Suntour crank on the drivetrain side of the cranks. Insert another at 180 degrees on the other side of the cranks. Use opposing force with the two wrenches to loosen the 8-mm hex screws on the cranks. from here
Esta resposta foi útil?
@oldturkey03 That’s what I tried doing but the space to slide the socket or the wrench in is too little
To little how? there are deep socket wrenches that have a handle on the side. Possible to use one of those? Any chance you can take a couple of pictures and post those with your QUESTION so that we can evaluate? Adicionar imagens a uma pergunta já existente
You got Instagram so I can ft you
No. Sorry all I do is iFixit. No social media :-(
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 480
