replace battery charging port
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Ralph Cross if you are talking about the lightning port, check this guide iPad 5 Wi-Fi Logic Board Replacement step 88 and others
Esta resposta foi útil?
I am not sure what you are asking, but if you are wondering what part you should replace should be easy, use an amp reader to see if the motherboard is pulling any power from the charge port if it's not then its a port replacement if it is then its a battery replacement.
How do I do this?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 638
