Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Black tape on logicboard important?
How important is to re apply the black tape on the bottom of the logicboard that covers different intergrated circuits, they are in about 5 places (i.e. under the Airport Extreme Card). thanks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
I can't speak with certainty on this but my initial feeling is: if you found black tape originally underneath that Airport Extreme Card then I would say go ahead and replace it with the exact same type (there are 2 different types of black tape). Remember, the shinny soft plastic black tape have a very "sticky" adhesive on it and you DON'T want any of that to get into/near any connection points on any part of the logic or I/O board.
Black tape serves and an insolation between electrical components, if electrical metal connectors/wires are extremely CLOSE to any metal body ground an "arc" can occur (depending on the voltage that goes thru that component) which can damage some sensitive components and or cause a SHUTDOWN.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
John será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 888
