Ir para o conteúdo principal
A Canon EOS 7D foi a primeira câmera profissional de ponta da Canon com um sensor APS-C recortado.
How to replace internal Battery
Is there a chance to replace the battery inside the camera?
After being exposed to water, it looks like there is a problem with it. every now and then the camera asks me to setup date and time.
Thanks for any help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi @mamf ,
Here’s a link that shows how to replace the date and time battery in your camera. It is a CR1616 lithium coin cell battery - example only
Hopefully it is only a battery problem and that the water has not caused more problems such as corrosion of the electronic components in the camera. (Check the date and time battery terminals in the camera to see if they are OK, i.e. bright and shiny and not showing signs of corrosion)
If replacing the date and time battery does not fix the problem, the camera may have to be opened and inspected to see if there are any other problems.
Here’s a link that explains in general what needs to be done.
Electronics Water Damage
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you so much! I‘ve always been told that the battery sits on the chip and there is no way to fix it, so I didn‘t look up how easy it actually is!
I will definitely try it...
por Compartilhar
Here is something from the manual you can follow:
  1. Set the power switch to <2>.
  2. Remove the battery.
  3. Take off the battery holder.
  4. Replace the battery.
  5. Insert the battery holder.
  6. Load the battery and close the cover.
If you need any help please reply to this answer.
Thanks,
John
Pontuação 2
3 comentários:
Thanks for your help! I didn‘t know it was so easy to access... will try to change the battery.
por Compartilhar
Yep! If you still need anything you can still always come to iFixIt for answers!
por Compartilhar
Purchased a second hand Canon EOS 7D with no manual, so very helpful.
por Compartilhar
Adicionar a sua resposta
Marius F será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 71
Ao todo: 6,959
