Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Perguntas Visualizar todos
Replacement headlight fuse location
It would appear that the driver's side headlight fuse is blown. The problem is that neither fuse box has an indication as to what fuse belongs to the headlights.
Esta é uma boa pergunta?
Pontuação 2
3 comentários
Where is the fuse located inside the car or under the hood
por
Fuses are good, what else could prevent hi & lo headlights from lighting up?
mpgrote@comcast.net
por
Where are the headlight fuses??
por
Adicionar um comentário
2 respostas
Solução escolhida
Okay just checked in the service manual and it looks like the following: 30 headlamp L low, 20 headlamp R low, 28 headlamp L high, 27 headlamp R high, hope this helps.
Esta resposta foi útil?
Pontuação 1
how does this help me find the fuse and or fuse box
Pontuação 0
2 comentários:
vrok73 it does not. It was not meant to help you. It was meant to help the OP. If you need some help with your vehice, just use this link and let us know what you need.
por
The fuses are in the Power Distribution Module located in a black box behind the fuse box on passenger side of RHD vehicle. Has four clips and very hard to get off! Has all the fuses that are not mentioned in the other three fuse boxes.
por
Adicionar a sua resposta
Frank será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 33,229
