Replacement headlight fuse location
It would appear that the driver's side headlight fuse is blown. The problem is that neither fuse box has an indication as to what fuse belongs to the headlights.
Esta é uma boa pergunta?
Okay just checked in the service manual and it looks like the following: 30 headlamp L low, 20 headlamp R low, 28 headlamp L high, 27 headlamp R high, hope this helps.
Esta resposta foi útil?
how does this help me find the fuse and or fuse box
vrok73 it does not. It was not meant to help you. It was meant to help the OP. If you need some help with your vehice, just use this link and let us know what you need.
The fuses are in the Power Distribution Module located in a black box behind the fuse box on passenger side of RHD vehicle. Has four clips and very hard to get off! Has all the fuses that are not mentioned in the other three fuse boxes.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 33,227
3 comentários
Where is the fuse located inside the car or under the hood
por Aretha
Fuses are good, what else could prevent hi & lo headlights from lighting up?
mpgrote@comcast.net
por Marv
Where are the headlight fuses??
por Phill Taylor
