Ir para o conteúdo principal
Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
Only one side plays when in wireless..
When i connect my headphones via Bluetooth it only plays sound in the one side but when I plug in the Aux cable it plays in both.
Esta é uma boa pergunta?
Pontuação 35
64 comentários
i had connected my Bluetooth beats solo 3's and started playing music and then i had paused them for a few seconds. then I hit play again and only the right side was playing music. anyone know whats up?
por
I had this problem as well when I got my brand new Beats Solo 3's. I fixed it by barely plugging in the tip of the aux chord into the headset while connected with bluetooth. Takes some playing around to figure out, but it works trust me.
por
my headphones are only playing out of one ear at a time back and fourth please help
por
I found this trick after hours of searching and failing. It doesn't look the greatest but it's the best solution I found so far. Instead of having to connect the aux cord in the headset (which would be stupid if it's the whole cord) which also may cut it out as well due to the headphones automatically switching over to aux setting. I personally noticed if I connect my cord that the Bluetooth will automatically turn off so the solution is to get aluminum foil. Make a small roll about the size of an aux tip and insert it in. You may need to play music and turn and twist it in order for it to hit the right spot for both speakers to come in but it works. I promise.
por
Thanks Dennis..foil worked on mine.
por
Exibir mais 59 comentários
Adicionar um comentário
8 respostas
Solução escolhida
Hi,
Have you tried a different BT source just to prove the problem is in the headphones?
If it is, it may be a dirty or faulty aux socket in the headphones. What headphone speaker is not playing, Left or Right?
Not quite sure if your headphones are like this but in some the aux socket has internal contacts that change over to disconnect the BT and connect the aux input when a cord is inserted.
If it is the Left speaker, by convention it is connected to the 'tip' connection (with its appropriate contacts) in the socket and if it is the Right speaker it is connected to the 'ring' connector (with its appropriate contacts) in the socket.
Here is a link to the Ifixit guide on how to repair your headphones. It is handy as it shows how to open the headphones so that the socket can be inspected and tested. In Step. 5 of the guide you can see (not very well) the aux socket.
Beats Solo HD Speaker Replacement
Esta resposta foi útil?
Pontuação 14
9 comentários:
It’s the right speaker on my wireless. Headphones
por
Same thing with mine
por
Right side of my head phones don’t work wirelessly, but when I attach the cord they work on both sides
por
I just got the same thing , I attached cable then when I took the cable off the right side stopped working , how can I flex this
por
Hi @Randy M
Do you mean that now both the right side and left side aren't working?
You may have to open the headphones and check if the aux connector is loose from the circuit board.
If it is wired as described above then a loose aux connector may cause no sound at all or no sound in only one earphone speaker,left or right.
por
Exibir mais 4 comentários
Gear Up For Future Repairs
Pergunta mais útil
1 - Connect with bluetooth and hear sound is not ok.
2 - Insert sound cable when it is playing hear sound ok
3 - When playing audio remove sound cable
4 - Power off/on headphones and reconnect bluetooth
Should be ok now.
Problem was i pluged in some cheap speaker via cable and i forgot to disconnect when i was done.
One night it stayed connected and in the morning i was having this trouble.
Pontuação 39
36 comentários:
@efes Thanks, works perfectly now!
por
I've been trying different things all day and this was the first thing to work. First try, too! Thanks a million!!
por
THIS IS AMAZING!!! YOU ARE AMAZING!!! I was so worried about my headphones, I was going to send them back, I am so happy, your solution worked instantly, thank you so much!! Genius, absolutely brilliant. Thank you! Both speakers work now like brand new! God bless you!
por
Mine is still not working properly. Maybe there is something I’m doing wrong. Do I connect the sound cord to both the headphones and the phone or connect them only to the phone?
por
I didn't understand what to do : where to insert sound cable, in the computer or in the headset ?
por
Exibir mais 31 comentários
heyyy everyone I also had the problem when I can only hear from one ear, and I was literally freaking out like crazy because they were only a week old. so I tired so many things like reseting direct from my headphones etc and nothing worked. so I connected them to my Mac and I clicked on 'open sound preference' and I altered the balance so it was even between the left and right. problem solved!
Pontuação 12
6 comentários:
thanks a bunch. I was freaking out for no reason. it was simple as that! thanks a bunch
por
this was also the issue for me, thanks!! I'm not sure why the balance was set to only the right, I certainly never set this myself...
por
Thank you so much. This totally worked! I was about to break open my precious headphones! I don't know why mac settings get so messed up :/
por
Thanks, this was the problem for me as well
por
hi thanks i just fix my am made up olny had one months thanks xxx
por
Exibir mais 1 comentário
Resetting the headphones also helps, I just did that and one of the suggestions here in a combo and now both ears are working well. Word of advise, there is different reset options depending on which series of Beats you are trying to fix. Mine are Solo 3's so I had to hold the power button and down volume button for 8 seconds to reset mine. Google your reset options if yours is not a Solo 3, I think others you hold the volume down button on the set and the multifunction button on the cord for 8 seconds until a blue and red light flashes.
Pontuação 1
2 comentários:
This worked perfectly, I have the discontinued Beats wireless and it worked fine. Thanks for the advice.
por
I have Solo HD I charged it and without disconnecting I connect it to my mobile it says 100 percent charged but after I disconnect my charging it doesn't on. . Only if I plug in my charger it switches on and connects to any device and if I unplug the charger it goes off..
por
My beat solo 3's right ear did not work while using Bluetooth but it did with an aux cable, I had tried everything but I did remember that this only occurred after the first time my headphones had run out of charge, I'm not sure if this will help anyone but all I did was turn them off, put them on charge for 2 seconds and then took out the charging cable and turned them on again. Worked for me, hope this helps someone else in My position who has tried everything
Pontuação 1
1 comentário:
Thanks a lot bro
por
I just had the same issue and based on a response above i stuck a pipe cleaner in the aux jack to clean it out and the right side started working again.
Pontuação 1
What´s up guys. After trying resetting, aluminum foil, using the plugging technique, etc. without solving the issue and just getting sloppy results (just one side working, connecting via bluetooth but no sound ) I took apart the right side of the headphones, then pushed gently the little metal sheets of the plug. I believe the malfunction was due to wear and bad contact of the cable plug. Anyway, I did that and they are working just fine. Be careful because there are several tiny cables welded to the board and can be broke easily. Hope this helps.
Pontuação 0
2 comentários:
Hey was your left or right side speaker not working?
por
Left side was not working.
por
First test whether it is a software or hardware issue. Do this by connecting your bluetooth to a device then determine if both earphones play equally. If not, plug the aux cord from your device into your headphones. Plug the aux cord slowly into your headphones to see if it switches from audio playing on one side to playing on both. Check your settings to determine if your sound is getting equally distributed. If so, The Aux Jack-in could be damaged or dirty or it could have a bad connection. You may need to disassemble your headphones and fix the problem. Headphone bluetooth transmitters and aux Jack-in run parallel circuits with one another. So when we know that only one side works the problem can be shifted to the other side, to be dealt with. Look for a faulty aux cable, or worn out jack’s. That could cause a loose connection as well.
Pontuação 0
Adicionar a sua resposta
ianconlon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 23
Últimos 7 dias: 119
Últimos 30 dias: 554
Ao todo: 602,515
