Ir para o conteúdo principal
Beats Solo HD Speaker Replacement
O que você precisa
  1. Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: passo 1, imagem 1 %32 Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: passo 1, imagem 2 %32
    • Remove the foam pads by twisting them counterclockwise.
    • The pads should release from the grooves that are housed on the speaker inside.
  2. Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: passo 2, imagem 1 %32 Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: passo 2, imagem 2 %32
    • There should be approximately three screws holding the right speaker. Unscrew them to gain access to the wiring of the speakers.
    • Keep the screws in a safe place. They are small and can easily be lost.
  3. Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: passo 3, imagem 1 %32 Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: passo 3, imagem 2 %32
    • Using safety gloves, desolder the two wires of the speaker.
    • Leave the desoldered and unstripped wires for the next step.
  4. Beats Solo HD Speaker Replacement, Repeat steps in reverse to re-assemble: passo 4, imagem 1 %32
    • Follow the instructions in reverse to put together the speaker in the housing, as well as the foam pad over the speaker.
    • Solder the new speaker to the two wires of the headphones.
    • Make sure to pack in all of the companents back into the housing when finished with this step.
  5. Beats Solo HD Speaker Replacement, Repeat steps for left speaker: passo 5, imagem 1 %32
    • If you need to repair the left speaker, there may be an additional step you need to take to replace the speakers. This takes the audio jack into account.
Conclusão
8 outras pessoas executaram este guia.
redacted
Membro desde: 10/11/14
544 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Donnelly Fall 2014 Membro de USF Tampa, Team 1-1, Donnelly Fall 2014
USFT-DONNELLY-F14S1G1
1 Membro
Autoria de 2 guias
3 comentários
Hello. I also have 1 damaged Monster Beats Solo. It was bought in 2013. The right speaker does not working properly - it sounds softer (opposite of lourder) than the left speaker and whenever I move, I can feel the sound of something loose inside the right ear cup/speaker. I already found some sellers selling the replacement speakers on ebay. Before buying the replacement parts, I decided to open the ear cup myself to check whether it is easy to open or not. However, so far I am unable to open it. I avoind using too much force because it is afraid that I might break the headphone.
SHAMSUL FAISAL MOHD HUSSEIN - Responder
According to some websites, the twist counter clockwise removal of the headphone pad is indicative of a fake beats solo HD, the genuine ones have fixed pads apparently. I can't guarantee this, but I do have a set of solo HDs with a faulty speaker and I can't easily remove the pad either
Simon16a - Responder
you forgot to mention polarity which matters if you mess that up ull get a lack of bass and phasing issues positive and negative should be clearly marked and a link to a proper replacement you should give proper instructions on how to check for proper polarity with a volt meter for those who dont know.
bob king - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 25
Últimos 30 dias: 141
Duração total: 106,105
