Ir para o conteúdo principal
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
Why isn’t my Thinkpad charging?
The Thinkpad is properly plugged in at both ports but is not building a charge at all.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
student question
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Test the power cord with a multimeter like in this guide.
Testing Power Cord Continuity
Then I would also test the power adapter is it is working with the multimeter
How To Use A Multimeter
If both test work fine then you know that your power adapter is fine and working.
You should also look at the power connector on he laptop so it is not loose because then the soldering might not lead the electricity. Good lock in testing.
Imagem de Electrical
Guia
Nível de dificuldade:
Muito fácil
1 - 5 minutes
Imagem de Electronics Skills
Guia
Fácil
5 minutes
Esta resposta foi útil?
Pontuação 2
Try replacing the battery or buying a new charger.
Pontuação 0
1 comentário:
Try pressing and holding down the power button for 3 - 4 seconds with the battery removed. Then try putting the battery back in, along with the AC adapter and see if it will charge. If this does not work try updating your motherboard.
If none of this works then try purchasing a new battery and AC adapter.
por
Adicionar a sua resposta
Lino Virgen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 408
