Why is my grinder overheating?
Recently when i use my grinder, it begins to get very hot after a short period of use. This does not seem normal, could you offer any suggestions to remedy this?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Hey Mackenzie, this is what iFixit suggests you to do if your grinder is overheating:
Grinder getting unusually hot while in use
When the grinder becomes hot and can’t be handled properly.
Use of grinder for long periods of time
While the grinder is in use a certain amount heat will be produced although if the grinder becomes too hot that it unpleasant to handle, you must stop shut off the grinder and allow it to cool off for some time and recheck to see if it has cooled off completely before reuse.
Build up of debris and rust
When an excessive amount of debris and rust build up, it can cause the grinder wheel to be clogged and overheat. In order to solve this issue you can refer to the Accumulation of Debris above section (I copy-pasted the section below).
From use debris can be cause of low resolution when air particles get inside of the grinder. In order to resolve this issue you will have to clean the moving components of the grinder and add a little lubrication oil to keep it moving.
-More troubleshooting fixes can be found here
-Let me know if this helps.
Esta resposta foi útil?
cleaning the grinding so more hot
machine inside cleaning so many more time heat continuances
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 13,855
5 comentários
student question
por mayer
some time field coil burn angle grander
wht is the reason
por Manzoor Ahmed
My grinder burned, what's the reason
por Tara Tiwari
hello sir i have 9" angle grander . in working time smoke com inside the body . when i open the grander . armachor is burn . why armachor burn what is the reason
por Manzoor Ahmed
armachor burning reason also carbon brush is crack
por Manzoor Ahmed
