Ir para o conteúdo principal
Chef's Choice Model M115, made by Edgecraft Corporation. Released in 2013.
This device does not sharpen my knives well
No matter how many times I run my knife thru the device it does not sharpen. What could be the problem? I am considering throwing the device away if I cannot fix it myself.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
All that thing really does is regrind the steel at the proper angle. On a good knife that needs to be done every couple of years or so. The better thing to use is a steel which does not remove metal. Here's a good video on how to do it: https://www.youtube.com/watch?v=MmO_kphe...
Esta resposta foi útil?
Pontuação 1
Make sure you have read the manual and are following the correct sharpening procedures. This issue is also covered in our troubleshooting guide
Pontuação 0
1 comentário:
Try that link again.
por
Adicionar a sua resposta
Zachary Grounds será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 590
