Ir para o conteúdo principal
The Epson Stylus Photo R2400 is a color inkjet photo printer made by Epson and marketed towards photography enthusiasts and professionals.
Service Required message displays in print utility window
After changing an ink cartridge, my printer won't respond. The print head seems immobile, the top and middle lights blink on/off red (paper feed and ink cartridge change lights). A message in utility window says something about parts may be at or near the end of their life.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Did you use an original part or so called comparable ink?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Answering for completion
This error is related to the WIC/waste ink pads. If you see the paper and ink lights flashing like this with this error, it's the waste ink with the cryptic Epson error. The newer ones usually say the ink pads are at the end of their service life.
It can be cleared with a leaked copy of the Epson adjustment tool, or WIC Reset Utility. However, you need to either divert the waste ink outside of the unit or take the entire thing apart to clean the pads out or it will make a mess. Some have a panel you can drill out or discard the inspection panel; others do not and you need to add the hole.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
crose será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 292
