Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Loud knocking noise and when the cycle completes
Hi!
I have a Kenmore 110 series washer with exactly the same issue. When the spin cycle engages, there is this terribly loud knocking noise and when the cycle completes, my clothes are still wet. The drum/ tub still moves no problem in the wash cycle. So is this a symptom that I should get the belt replaced or is it a transmission issue?
Thanks!
Iris
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
The drive belt really does not care which cycle your washer is on. Its only function is to connect the motor to the transmission. So, if it spins the drum in any cycle, your belt is okay. Are you pretty handy when it comes to repairs?
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for your reply.
I don't proclaim to be a handyman. But I can do basic stuff if its not rocket science :)
por
Nope, no rocket science involved with this one;-). Start off by giving us the complete model or serial number. I suppose it starts with something like 110.XXXXXXX
por
I have a Canmore 110 series washer,when the spin cycle engages,there is terribly loud knocking nois. What could it be.
Pontuação 0
Adicionar a sua resposta
iriscscott será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 692
