Ir para o conteúdo principal
iPhone 15 Pro Max Battery Replacement
O que você precisa
  1. iPhone 15 Pro Max Battery Replacement, Prepare your phone for disassembly: passo 1, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Prepare your phone for disassembly: passo 1, imagem 2 %32
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Pro Max Battery Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Tape over any cracks: passo 2, imagem 2 %32
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Max Battery Replacement, Mark your opening picks: passo 3, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Mark your opening picks: passo 3, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Mark your opening picks: passo 3, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Pro Max Battery Replacement, Remove the pentalobe screws: passo 4, imagem 1 %32
    • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
  5. iPhone 15 Pro Max Battery Replacement, Secure the back glass: passo 5, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Secure the back glass: passo 5, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Secure the back glass: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open the screen, you need to secure the back glass with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
  6. iPhone 15 Pro Max Battery Replacement, Secure an Anti-Clamp: passo 6, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Secure an Anti-Clamp: passo 6, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Secure an Anti-Clamp: passo 6, imagem 3 %32
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Pro Max Battery Replacement, Create a gap under the screen: passo 7, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Create a gap under the screen: passo 7, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Create a gap under the screen: passo 7, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  8. iPhone 15 Pro Max Battery Replacement, Insert an opening pick: passo 8, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Insert an opening pick: passo 8, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Insert an opening pick: passo 8, imagem 3 %32
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Pro Max Battery Replacement, Heat the bottom edge: passo 9, imagem 1 %32
  10. iPhone 15 Pro Max Battery Replacement, Insert an opening pick: passo 10, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Insert an opening pick: passo 10, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Insert an opening pick: passo 10, imagem 3 %32
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Pro Max Battery Replacement, Screen information: passo 11, imagem 1 %32
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  12. iPhone 15 Pro Max Battery Replacement, Separate the bottom edge adhesive: passo 12, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Separate the bottom edge adhesive: passo 12, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Separate the bottom edge adhesive: passo 12, imagem 3 %32
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Pro Max Battery Replacement, Heat the right edge: passo 13, imagem 1 %32
    • Heat the right edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Max Battery Replacement, Position the opening pick: passo 14, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Position the opening pick: passo 14, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Position the opening pick: passo 14, imagem 3 %32
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  15. iPhone 15 Pro Max Battery Replacement, Release the right clip: passo 15, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Release the right clip: passo 15, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Release the right clip: passo 15, imagem 3 %32
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  16. iPhone 15 Pro Max Battery Replacement, Separate the right edge adhesive: passo 16, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Separate the right edge adhesive: passo 16, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Separate the right edge adhesive: passo 16, imagem 3 %32
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  17. iPhone 15 Pro Max Battery Replacement, Heat the top edge: passo 17, imagem 1 %32
    • Heat the top edge of the screen until it's hot to the touch.
  18. iPhone 15 Pro Max Battery Replacement, Separate the top edge adhesive: passo 18, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Separate the top edge adhesive: passo 18, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Separate the top edge adhesive: passo 18, imagem 3 %32
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  19. iPhone 15 Pro Max Battery Replacement, Heat the left edge: passo 19, imagem 1 %32
    • Heat the left edge of the screen until it's hot to the touch.
  20. iPhone 15 Pro Max Battery Replacement, Separate the left edge adhesive: passo 20, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Separate the left edge adhesive: passo 20, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Separate the left edge adhesive: passo 20, imagem 3 %32
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  21. iPhone 15 Pro Max Battery Replacement, Swing open the screen: passo 21, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Swing open the screen: passo 21, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Swing open the screen: passo 21, imagem 3 %32
    • Gently swing open the screen to the left of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
  22. iPhone 15 Pro Max Battery Replacement, Unfasten the logic board cover: passo 22, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Unfasten the logic board cover: passo 22, imagem 2 %32
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
    • One 2.1 mm‑long screw
    • Five 1.5 mm‑long screws
  23. iPhone 15 Pro Max Battery Replacement, Remove the logic board cover: passo 23, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the logic board cover: passo 23, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Remove the logic board cover: passo 23, imagem 3 %32
    • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
    • Remove the cover.
  24. iPhone 15 Pro Max Battery Replacement, Disconnect the battery: passo 24, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Disconnect the battery: passo 24, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Disconnect the battery: passo 24, imagem 3 %32
    • Use the tip of an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  25. iPhone 15 Pro Max Battery Replacement, Disconnect the ambient light sensor: passo 25, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Disconnect the ambient light sensor: passo 25, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
  26. iPhone 15 Pro Max Battery Replacement, Disconnect the screen: passo 26, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Disconnect the screen: passo 26, imagem 2 %32
    • Disconnect the screen press connector.
  27. iPhone 15 Pro Max Battery Replacement, Remove the screen: passo 27, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the screen: passo 27, imagem 2 %32
    • Remove the screen.
    • During reassembly, stop here and use this guide to install new screen adhesive.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  28. iPhone 15 Pro Max Battery Replacement, Unfasten the loudspeaker: passo 28, imagem 1 %32
    • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
    • Three 2.1 mm screws
    • One 2.9 mm screw
  29. iPhone 15 Pro Max Battery Replacement, Separate the tape: passo 29, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Separate the tape: passo 29, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Separate the tape: passo 29, imagem 3 %32
    • A piece of tape connects the top edges of the Taptic Engine and loudspeaker.
    • Insert an opening pick under the tape in the small gap between the Taptic Engine and the loudspeaker.
    • Slide the pick toward the left edge of the phone to separate the tape from the Taptic Engine.
  30. iPhone 15 Pro Max Battery Replacement, Remove the loudspeaker: passo 30, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the loudspeaker: passo 30, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Remove the loudspeaker: passo 30, imagem 3 %32
    • Insert the flat end of a spudger between the right edge of the loudspeaker and the frame.
    • Pry up until you can grab the loudspeaker with your fingers.
    • Remove the loudspeaker.
  31. iPhone 15 Pro Max Battery Replacement, Disconnect the Taptic Engine: passo 31, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Disconnect the Taptic Engine: passo 31, imagem 2 %32
    • Use the tip of your spudger to pry up and disconnect the Taptic Engine press connector.
  32. iPhone 15 Pro Max Battery Replacement, Remove the grounding clip: passo 32, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the grounding clip: passo 32, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Remove the grounding clip: passo 32, imagem 3 %32
    • Remove the two screws securing the grounding clip:
    • One 1.2 mm Phillips #000 screw
    • One 1.9 mm tri-point Y000 screw
    • Use tweezers to remove the grounding clip.
  33. iPhone 15 Pro Max Battery Replacement, Unfasten the Taptic Engine: passo 33, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the Taptic Engine:
    • One 2.9 mm Phillips #000 screw
    • One 3.8 mm standoff screw
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  34. iPhone 15 Pro Max Battery Replacement, Remove the Taptic Engine: passo 34, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the Taptic Engine: passo 34, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Remove the Taptic Engine: passo 34, imagem 3 %32
    • Insert the flat end of a spudger between the left edge of the Taptic Engine and the frame.
    • Pry up until you can grab the Taptic Engine with your fingers.
    • Remove the Taptic Engine.
  35. iPhone 15 Pro Max Battery Replacement, Adhesive information: passo 35, imagem 1 %32
    • Three sections of stretch release adhesive secure the battery to the frame—two along the bottom and one on top.
    • Each strip has a black pull tab at its end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab out from underneath the battery.
    • The strips loosen when stretched, but might break off before you can fully remove them, especially the top edge strip. If any break, don't worry! Keep reading for an alternate way to remove the battery.
  36. iPhone 15 Pro Max Battery Replacement, Separate the pull tabs: passo 36, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Separate the pull tabs: passo 36, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Separate the pull tabs: passo 36, imagem 3 %32
    • Don't puncture or dent the battery with your tool, as it can leak dangerous chemicals or catch fire if damaged.
    • Use the tip of an opening pick to gently unstick an edge of an adhesive pull tab from the edge of the battery.
    • Use blunt nose tweezers to grip the edge of the pull tab and pull it completely off the edge of the battery.
    • Repeat for the other two pull tabs.
  37. iPhone 15 Pro Max Battery Replacement, Remove the stretch release adhesive: passo 37, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the stretch release adhesive: passo 37, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Remove the stretch release adhesive: passo 37, imagem 3 %32
    • Pull one of the pull tabs out from under the battery until you can grip it with your fingers or wrap it around your tool.
    • Hold the phone steady using the edges of the frame—don't press down on the battery.
    • Pull the strip slowly, evenly, and at a low angle without dragging on other components.
    • Continue pulling, re-gripping or wrapping it around your tool as you go, until the strip fully releases from under the battery.
    • If the strip breaks off, try to retrieve it. If you can't grip it from under the battery, move on to the next step.
    • Repeat this step for the other two strips.
  38. iPhone 15 Pro Max Battery Replacement, Alternate method to remove the battery: passo 38, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Alternate method to remove the battery: passo 38, imagem 2 %32
    • If you removed all three stretch release adhesive strips, congratulations—you can now remove the battery! If not, follow the next two steps to separate the adhesive with isopropyl alcohol and a plastic card.
    • If the top strip remains, prop up the top edge of the phone.
    • If either of the bottom strips remain, prop up the left edge of the phone (the side with the volume buttons).
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the elevated edge of the battery.
    • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
  39. iPhone 15 Pro Max Battery Replacement, Pry up the battery: passo 39, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Pry up the battery: passo 39, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Pry up the battery: passo 39, imagem 3 %32
    Plastic Cards
    $2.99
    • Don't bend or crease your battery. If the adhesive feels stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Insert the short edge of a plastic card between the bottom edge of the battery and the frame.
    • Be careful not to scrape the frame underneath the battery—the wireless charging coil is exposed near the center.
    • Gently pry up the battery until the adhesive fully separates.
    • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
  40. iPhone 15 Pro Max Battery Replacement, Remove the battery: passo 40, imagem 1 %32 iPhone 15 Pro Max Battery Replacement, Remove the battery: passo 40, imagem 2 %32 iPhone 15 Pro Max Battery Replacement, Remove the battery: passo 40, imagem 3 %32
    Stretch Release Battery Adhesive
    $3.99
    • Remove the battery.
    • To install a new battery:
    • Clean your frame with isopropyl alcohol and a lint-free or microfiber cloth.
    • Before applying adhesive, temporarily reconnect your new battery and place it in its recess to check if it fits and that the cable reaches the socket on the logic board. Disconnect the battery before continuing.
    • Check out this guide to apply new stretch release adhesive strips to your battery, if it doesn't already come with adhesive installed.
    • If you don't have stretch release adhesive, use thin, double-sided tape to secure it.
Conclusão
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
17 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
81.013 Reputação
Autoria de 455 guias
Equipe
Guide Team Membro de Guide Team
Staff
Membros da 9
Autoria de 11.335 guias
2 comentários
@cashewclay The Apple self service manual says it needs a system configuration after installing a battery, I'm assuming this would set up the battery health feature? They provide instructions on how to perform a system configuration. Same goes for replacing the display and other components. I think it would only work for Apple genuine parts, but would be interesting to try with 3rd party too.
swaplink - Responder
You're right that Apple's tool restores some functionality, like battery health. Unfortunately, they've woven in a verification step, checking that you have exactly the right battery that they sent to you. Using a third-party battery, or even the wrong "genuine" Apple battery, will cause the system configuration to reject the replacement. This is subject to change, and may only be accurate as of the time this guide was published.
Clay Eickemeyer -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 57
Últimos 7 dias: 454
Últimos 30 dias: 1,838
Duração total: 36,151
