Ir para o conteúdo principal
WRS315SDHW Control Board Replacement
nicO
nicO e 3 outros colaboradores
Última atualização em June 1, 2023
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace the control board in your Whirlpool WRS315SDHW Refrigerator.
The control board processes the inputs for the dispenser assembly and other related assemblies. If your refrigerator is not dispensing properly, or if the dispenser buttons on your refrigerator aren't working, then your control board might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
  1. WRS315SDHW Control Board Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: passo 2, imagem 1 %32 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: passo 2, imagem 2 %32
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: passo 3, imagem 1 %32 WRS315SDHW Control Board Replacement, Remove the dispenser panels: passo 3, imagem 2 %32 WRS315SDHW Control Board Replacement, Remove the dispenser panels: passo 3, imagem 3 %32
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: passo 4, imagem 1 %32
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: passo 5, imagem 1 %32 WRS315SDHW Control Board Replacement: passo 5, imagem 2 %32 WRS315SDHW Control Board Replacement: passo 5, imagem 3 %32
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: passo 6, imagem 1 %32 WRS315SDHW Control Board Replacement, Disconnect the control board: passo 6, imagem 2 %32 WRS315SDHW Control Board Replacement, Disconnect the control board: passo 6, imagem 3 %32
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: passo 7, imagem 1 %32 WRS315SDHW Control Board Replacement: passo 7, imagem 2 %32
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: passo 8, imagem 1 %32
    • Remove the control board.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 89 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 705 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 411
