Ir para o conteúdo principal
WRS315SDHW Dispenser Assembly Replacement
O que você precisa
    1. WRS315SDHW Dispenser Assembly Replacement, Safety precautions: passo 1, imagem 1 %32
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Pergunte ao FixBot
      Comentar
    1. WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: passo 2, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: passo 2, imagem 2 %32
      • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
      • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
      Pergunte ao FixBot
      Comentar
    2. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: passo 3, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: passo 3, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: passo 3, imagem 3 %32
      • Pull the dispenser panels straight down to separate them from the chassis.
      • Remove the dispenser panels.
      Pergunte ao FixBot
      Comentar
    3. WRS315SDHW Dispenser Assembly Replacement, Unfasten the control board: passo 4, imagem 1 %32
      • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
      Pergunte ao FixBot
      Comentar
    4. WRS315SDHW Dispenser Assembly Replacement: passo 5, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement: passo 5, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement: passo 5, imagem 3 %32
      • Tilt the bottom of the control board away from the chassis to release its clips.
      • Pull straight down to separate the control board enough to access its connectors.
      Pergunte ao FixBot
      Comentar
    5. WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: passo 6, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: passo 6, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: passo 6, imagem 3 %32
      • Disconnect the large connector attached to the right edge of the control board.
      Pergunte ao FixBot
      Comentar
    6. WRS315SDHW Dispenser Assembly Replacement: passo 7, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement: passo 7, imagem 2 %32
      • Disconnect the small connector attached to the left edge of the control board.
      Pergunte ao FixBot
      Comentar
    7. WRS315SDHW Dispenser Assembly Replacement, Remove the control board: passo 8, imagem 1 %32
      • Remove the control board.
      Pergunte ao FixBot
      Comentar
    1. WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: passo 9, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: passo 9, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: passo 9, imagem 3 %32
      • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
      • Remove the plastic clip.
      Pergunte ao FixBot
      Comentar
    2. WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: passo 10, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: passo 10, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: passo 10, imagem 3 %32
      • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
      • Pull the water hose straight up to disconnect it.
      Pergunte ao FixBot
      Comentar
    3. WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: passo 11, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: passo 11, imagem 2 %32
      • Reposition the cables so they lay in front of the top plastic clip.
      Pergunte ao FixBot
      Comentar
    4. WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: passo 12, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: passo 12, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: passo 12, imagem 3 %32
      • There are two plastic clips that secure the dispenser assembly in the chassis.
      • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
      • Repeat for the other plastic clip to completely separate the dispenser assembly from the chassis.
      Pergunte ao FixBot
      Comentar
    5. WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: passo 13, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: passo 13, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: passo 13, imagem 3 %32
      • Pull the dispenser assembly away from the chassis enough to access its connectors.
      Pergunte ao FixBot
      Comentar
    6. WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: passo 14, imagem 1 %32 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: passo 14, imagem 2 %32 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: passo 14, imagem 3 %32
      • While performing this step, support the dispenser assembly so it doesn't fall.
      • Disconnect the connector attached to the dispenser assembly.
      Pergunte ao FixBot
      Comentar
    7. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser assembly: passo 15, imagem 1 %32
      • Remove the dispenser assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.990 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 23
Últimos 30 dias: 122
Ao todo: 1,521
