Ir para o conteúdo principal
VTech MobiGo Touch Learning System Screen Replacement
Daniel Kresge
Daniel Kresge e 4 outros colaboradores
Última atualização em 5 de ago de 2024
4 minutos
Moderado
Faltando Passos
Introdução
Ir para o passo 1
This guide shows users how to replace the screen. By first taking the device apart until they can reach the screen so that they can replace it.
O que você precisa
Ferramentas
Exibir mais…
  1. VTech MobiGo Touch Learning System Screen Replacement, Case: passo 1, imagem 1 %32
    • Remove the battery covers and the four batteries.
  2. VTech MobiGo Touch Learning System Screen Replacement: passo 2, imagem 1 %32 VTech MobiGo Touch Learning System Screen Replacement: passo 2, imagem 2 %32
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. VTech MobiGo Touch Learning System Screen Replacement: passo 3, imagem 1 %32 VTech MobiGo Touch Learning System Screen Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, imagem 1 %32
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. VTech MobiGo Touch Learning System Screen Replacement: passo 5, imagem 1 %32
    • Remove the three "L" shaped brackets and the spring.
  6. VTech MobiGo Touch Learning System Screen Replacement: passo 6, imagem 1 %32
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. VTech MobiGo Touch Learning System Screen Replacement: passo 7, imagem 1 %32
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
  8. VTech MobiGo Touch Learning System Screen Replacement, Screen: passo 8, imagem 1 %32
    • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
  9. VTech MobiGo Touch Learning System Screen Replacement: passo 9, imagem 1 %32
    • Remove the black tape
  10. VTech MobiGo Touch Learning System Screen Replacement: passo 10, imagem 1 %32
    • Remove the circuit board from the back of the screen.
    • The circuit board has double sided tape on the back side holding it to the screen.
  11. VTech MobiGo Touch Learning System Screen Replacement: passo 11, imagem 1 %32
    • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
    mine i don’t know about
    Jesse Eagan - Responder
  12. VTech MobiGo Touch Learning System Screen Replacement: passo 12, imagem 1 %32
    • Resolder the new screens ribbon cable on the the circuit board.
    • Always be careful when soldering.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Daniel Kresge
Membro desde: 09/01/15
385 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membros
Autoria de 17 guias
1Comentário do guia
mine i droped a rock on so i don’t get it
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 840
