Toshiba Satellite U840W RAM Replacement
Introdução
Vá para o passo 1Is your Toshiba Satellite performance being rather slow lately? If so, these steps will show you how to replace the RAM on your motherboard.
O que você precisa
Ferramentas
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
Push each latch arm away from the RAM card until the card lifts up, away from the motherboard.
