Ir para o conteúdo principal
Toshiba Satellite U840W 12V Charging Port Replacement
O que você precisa
  1. Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: passo 1, imagem 1 %32 Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: passo 1, imagem 2 %32
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W 12V Charging Port Replacement: passo 2, imagem 1 %32 Toshiba Satellite U840W 12V Charging Port Replacement: passo 2, imagem 2 %32 Toshiba Satellite U840W 12V Charging Port Replacement: passo 2, imagem 3 %32
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W 12V Charging Port Replacement: passo 3, imagem 1 %32 Toshiba Satellite U840W 12V Charging Port Replacement: passo 3, imagem 2 %32 Toshiba Satellite U840W 12V Charging Port Replacement: passo 3, imagem 3 %32
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W 12V Charging Port Replacement: passo 4, imagem 1 %32
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W 12V Charging Port Replacement, 12V Charging Port: passo 6, imagem 1 %32
    • Remove the connector from the motherboard.
    • This separates the only connection from the motherboard to the cover.
  6. Toshiba Satellite U840W 12V Charging Port Replacement: passo 7, imagem 1 %32
    • Remove the screw holding 12v charging port to the cover.
  7. Toshiba Satellite U840W 12V Charging Port Replacement: passo 8, imagem 1 %32
    • Remove the 12v charging port from the cover.
Conclusão
Joshua Pedersen
Membro desde: 02/04/19
217 Reputação
Autoria de 1 guia
Equipe
Gateway, Team S1-G1, Saknee Spring 2019 Membro de Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 261
