Ir para o conteúdo principal
Thrustmaster T248 Manual recalibration
Formica Fusca
Formica Fusca e 2 outros colaboradores
Última atualização em September 5, 2024
1 minuto
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
Guide on how to manually re-center the wheel. Helps when your physical wheel is not synced with in-game wheel and some other problems.
  1. Thrustmaster T248 Manual recalibration, Set rotation Angle to 900°: passo 1, imagem 1 %32
    • Open the Thrustmaster Control panel application and set the angle to 900°
    • Unplug and re-plug T248 to USB port.
    • Wait for auto-calibration to finish.
  2. Thrustmaster T248 Manual recalibration, Steer the wheel all the way to the left: passo 3, imagem 1 %32
    • Keep turning the wheel until you reach a physical stop
  3. Thrustmaster T248 Manual recalibration, Steer the wheel all the way to the right: passo 4, imagem 1 %32
  4. Thrustmaster T248 Manual recalibration, Center your wheel: passo 5, imagem 1 %32
    • Perfectly center your wheel.
    • Keep in mind that rotation is set to 900°.
  5. Thrustmaster T248 Manual recalibration, Press and hold specified buttons until you see "SAVE" on the screen: passo 6, imagem 1 %32
    • Press and hold the buttons as shown on the picture. Wait for screen to say "SAVE" and release the buttons.
    • Xbox version of T248 uses same buttons, but the symbols on them are different.
Linha de Chegada
Formica Fusca
Membro desde: 08/01/24
2.587 Reputação
Autoria de 15 guias
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 62
Últimos 30 dias: 222
Ao todo: 1,633
