Ir para o conteúdo principal
Thread a Sewing Machine
Brittany McCrigler
Brittany McCrigler e 4 outros colaboradores
Última atualização em 14 de out de 2024
5 minutos
Fácil
Guia em destaque
Patagonia
Introdução
Ir para o passo 1
You don’t need a sewing machine to sew. But a machine can save you a lot of time when you make repairs, so if you have access to a sewing machine, here’s how to thread it. In this guide we’re using a Bernina 830, but the process will be similar for most sewing machines. Refer to your sewing machine’s owner’s manual for specific directions on how to thread the machine.
O que você precisa
Ferramentas
  1. Thread a Sewing Machine, Thread a Sewing Machine: passo 1, imagem 1 %32 Thread a Sewing Machine, Thread a Sewing Machine: passo 1, imagem 2 %32 Thread a Sewing Machine, Thread a Sewing Machine: passo 1, imagem 3 %32
    • Place a spool on the pin. Pull the thread from the spool straight out, following the length of the machine.
    • Hook the thread under the eyelet on the outer edge of the machine.
    • With one hand, hold the spool steady. Using the eyelet as a pivot, pull the string perpendicular with the other hand. Lay the thread into the slot, which bisects the top of the machine.
  2. Thread a Sewing Machine: passo 2, imagem 1 %32 Thread a Sewing Machine: passo 2, imagem 2 %32 Thread a Sewing Machine: passo 2, imagem 3 %32
    • Pull the thread all the way across the slot on the top of the sewing machine. Then, pull the thread down toward the presser foot.
    • There is a lever just above the presser foot. Hook the thread under the lever until it rests in the crux.
    • Pull the thread back up toward the top of the machine.
  3. Thread a Sewing Machine: passo 3, imagem 1 %32 Thread a Sewing Machine: passo 3, imagem 2 %32 Thread a Sewing Machine: passo 3, imagem 3 %32
    • At the top of the machine, lead the thread along the groove of the take-up lever.
    • Once you've fed the thread into the crux of the take-up lever, pull the thread back down towards the presser foot.
    • If you've threaded correctly, your thread should form a complete zigzag—first down, then up, then back down all the way to the presser foot.
  4. Thread a Sewing Machine: passo 4, imagem 1 %32 Thread a Sewing Machine: passo 4, imagem 2 %32
    • Hook the thread behind the small, bent arm where the needle attaches to the machine.
    • Guide the thread, from front to back, through the eye of the needle, leaving a loose end of approximately 10 cm.
    • If the end of your thread has frayed and you cannot guide it through the eye of the needle, snip off the frayed end and try again.
  5. Thread a Sewing Machine: passo 5, imagem 1 %32 Thread a Sewing Machine: passo 5, imagem 2 %32
    • After you've guided the thread through the eye of the needle, pull the thread down and through the large groove in the presser foot.
    • Hook the thread along the groove and pull it perpendicular toward the body of the machine.
  6. Thread a Sewing Machine: passo 6, imagem 1 %32 Thread a Sewing Machine: passo 6, imagem 2 %32 Thread a Sewing Machine: passo 6, imagem 3 %32
    • While continuing to hold the top thread advance the sewing machine with the balance wheel (also know as the hand wheel), to pick up the bobbin thread.
    • Only turn the balance wheel in the direction that advances the machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
    • Grasp these two threads between pinched fingers and pull them in unison toward the body of the machine, leaving two to three inch tails.
  7. Thread a Sewing Machine: passo 7, imagem 1 %32 Thread a Sewing Machine: passo 7, imagem 2 %32
    • Slide the sewing machine table onto the machine.
    • Hold the sewing machine table so that is lays flush with the sewing machine.
  8. Thread a Sewing Machine: passo 8, imagem 1 %32 Thread a Sewing Machine: passo 8, imagem 2 %32
    • Lock the sewing machine table into place by pushing the clamp lever to the right until it engages.
Linha de Chegada
11 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Brittany McCrigler
Membro desde: 03/05/12
90.144 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 22.508 guias
9Comentários do guia
Sewing machine comparison and reviews
Detailed and straight to the point comparison and product reviews of sewing machines. Insights on features, performance and best buying practices.
https://www.comparencart.com
cart - Responder
Sewing machine reviews
Best Sewing Review is here to help you what you need to know about in sewing . Check here https://bestsewingreview.com
Daisy - Responder
A good site to get knowledge about the <a href="http://www.buysewingmachineguide.com/"> sewing machine. </a>
sewing machne - Responder
is it possible to add some videos on the site it will be very helpful for us to follow this as I am also sharing my knowledge here https://topsewingmachinereviews.com/
Md.Harun Rashid - Responder
How do u thread a sewmor model 202?
Helen jennings - Responder
Want to learn about sewing machines and sewing? Checkout of sewing machine site
brainmiller - Responder
wooow Brittany McCrigler the steps on how to thread a sewing machine are awesome. Trouble some when its time to fix the thread through the needle my eyes are kaput even at times when my glasses are on finally with enough struggle i have to fix it in order to complete a garment thanks
dani - Responder
This was SO helpful and informative. I’m probably at an intermediate skill level, and almost everything you said was useful and new info for me.
dani - Responder
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 78
Últimos 30 dias: 364
Ao todo: 59,966
