Ir para o conteúdo principal
Teenage Engineering OP-1 Display Replacement
Tobias Isakeit
Tobias Isakeit
Última atualização em 10 de jul de 2024
20 minutos
Moderado
Introdução
Ir para o passo 1
The display not only gives you useful information, it is also fun to watch the small animations while making sounds. If the display should fail this guide will show you how to replace it.
O que você precisa
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Teenage Engineering OP-1 Display Replacement, key removal: passo 1, imagem 1 %32 Teenage Engineering OP-1 Display Replacement, key removal: passo 1, imagem 2 %32 Teenage Engineering OP-1 Display Replacement, key removal: passo 1, imagem 3 %32
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 Display Replacement, removing scissors mechanisms: passo 2, imagem 1 %32 Teenage Engineering OP-1 Display Replacement, removing scissors mechanisms: passo 2, imagem 2 %32
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 Display Replacement, unscrew keyboard: passo 3, imagem 1 %32 Teenage Engineering OP-1 Display Replacement, unscrew keyboard: passo 3, imagem 2 %32 Teenage Engineering OP-1 Display Replacement, unscrew keyboard: passo 3, imagem 3 %32
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
    Your missing the ribbon decoupling step, unless you skipped it because it’s such a tight squeeze to get back in.
    William “Zoe” FitzGerald - Responder
    The concept of removing the square panels that the knobs sit on was skipped.
    Station 2Station - Responder
  4. Teenage Engineering OP-1 Display Replacement, Display: passo 4, imagem 1 %32 Teenage Engineering OP-1 Display Replacement, Display: passo 4, imagem 2 %32 Teenage Engineering OP-1 Display Replacement, Display: passo 4, imagem 3 %32
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
    • After reassembly you want to perform the three function tests (0, 1 and 2) from the OP-1 special start screen. You can enter this menu by holding the COM key when powering up.
Conclusão
5 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Tobias Isakeit
Membro desde: 03/31/14
126.906 Reputação
Autoria de 189 guias
Equipe
15Comentários do guia
It is really helping.
do you know where to get the screen?
thank you.
chefshin - Responder
I see that the part # is AMS260CM61 ver 2 by Samsung. However, I have not been able to source it online.
Mike - Responder
Hey guys,
Can someone from IFIXIT please let us know where we can buy the screen please.
my screen is cracked and i desperately need to replace it.
Thanks!
Jack - Responder
Hi Jack, unfortunately we do not know where to get a replacement screen for the OP-1. You might want to get in contact with the guys from Teenage Engineering directly. Sorry
Tobias Isakeit -
Jack, look for “part number 74-x000045”, there are few of them out there. Cheers.
Peter O -
What about the new rev 2.0 op-1
Can you source those screens ?
Newer push in connection.
Or anyone got the specs or compatible part number ?
Yes, also messaged t.e
Gadget - Responder
It appears there are three versions of the screen as of 2021-03-10; I cannot currently confirm if ver. 2 or ver. 3 are accurate, but will update in about a month when I receive a ver. 2 if they are not accurate:
ver. 1 : 74-x000045, can be currently found on eBay ; this version is the one is shown in the example
ver. 2 : AMDM001, will need to purchase from LCD-focused or bulk electronics sites such as enlcd; this one has a connector piece on the ribbon to snap onto the circuit board, and is smaller than 74-x000045; it is NOT interchangeable with ver. 1
ver. 3 : AMEJ006D, even worse scarcity than ver. 2, only found one listing on eBay, none from LCD-focused or bulk electronics sites; looks similar to ver. 2; it is also NOT interchangeable with ver. 1. However, it looks similar to ver. 2, so it MIGHT be interchangeable with ver. 2 — I haven’t been able to test.
Anonymous - Responder
Update: the AMDM001 arrived from lcdperfect, and I can confirm it works correctly with version 2 of the OP-1 (the version with the smaller screen and higher circuit board that the screen connects to).
Anonymous -
This is some valuable information here. Thanks for sharing
Tobias Isakeit -
I just did this and it worked! Thank you for this tutorial.
The original problem for me was a progressive glitching. The screen was kind of readable for a few months but eventually went completely dark aside from a random pixel or two.
I ordered my replacement screen from from this seller on AliExpress. The first screen didn't work but thankfully they had free returns and all that was lost was a few months of slow shipping time. ;)
Of note: Your replacement screen might be flipped upside down. Don't worry. Restart your OP-1 while holding down the COM button and it will prompt you to flip the screen by hitting Shift-4.
One thing I noticed that might help people squeeze some new life out of an old screen: When I was replacing the screen I decided to carefully peel the sticker connector off the back of the old screen. I reconnected it one last time and... it started working again. Albeit with some slight ghosting. If your screen seems otherwise dead, maybe give that a try as a last resort.
Elling Lien - Responder
How to order display please i need to fix it
pon mani - Responder
Hello, I dont see where to buy the display? It is available for buying?
TOMI LEBRERO - Responder
Hello, It´s possible buying a screen of OP 1? Thanks
Hi guys! Just had a leaking roof and water went intocmy Op1 Field. After letting it dry for a few days, I turned ir on today and everithing works but the screen is dead. I e-maild teenage bit no answer so far. Could you give me some help please? Thank you!!
Nano - Responder
teenage engineering dont support this anymore , good luck .. my screen has gone too .. be keen to hear if anyone finds a solution
Ryan Sanders - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 88
Ao todo: 15,360
