Ir para o conteúdo principal
TCA Quadrant Calibration
Formica Fusca
Formica Fusca e um outro colaborador
Última atualização em 8 de nov de 2024
2 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
How to re-calibrate the levers of the Quadrant, in case they are not aligned or not providing correct input in the Flight Simulator.
    • If you have your Quadrant plugged-in, then unplug it.
  1. TCA Quadrant Calibration, Lower all levers: passo 2, imagem 1 %32 TCA Quadrant Calibration, Lower all levers: passo 2, imagem 2 %32
    • Mover each of the 3 levers to the lowest position.
  2. TCA Quadrant Calibration, Press and Hold the Indicated button.: passo 3, imagem 1 %32
    • Press and hold the button highlighted.
  3. TCA Quadrant Calibration, Plug to USB port While holding the button.: passo 4, imagem 1 %32
    • Connect your Quadrant to USB port while still holding the button.
    • Once connected, wait a few seconds and let go of the button
    • You can connect to:
    • USB port of your PC.
    • USB Port at the back of your TCA Yoke.
    • USB port of your Xbox.
    • Do not use USB Hubs or extension cables.
  4. TCA Quadrant Calibration, Move all levers up: passo 5, imagem 1 %32 TCA Quadrant Calibration, Move all levers up: passo 5, imagem 2 %32
    • Pull each levers to the highest position.
    • Move the levers smoothly for better calibration.
  5. TCA Quadrant Calibration, Press the Indicated buttons: passo 6, imagem 1 %32
    • Press these 2 buttons at the same time.
    • This should save the calibration.
Linha de Chegada
Gear Up For Future Repairs
Shop all
Formica Fusca
Membro desde: 08/01/24
2.595 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 231
