Ir para o conteúdo principal
Sony Vaio VGN-SZ120P Keyboard Replacement
Ashley Brooks
Ashley Brooks e 7 outros colaboradores
Última atualização em December 11, 2022
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
If you have not been able to fix your keyboard issues via our Troubleshooting Guide, then please follow the steps below to replace your keyboard.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony Vaio VGN-SZ120P Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Keyboard Replacement: passo 2, imagem 1 %32
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Keyboard Replacement: passo 4, imagem 1 %32 Sony Vaio VGN-SZ120P Keyboard Replacement: passo 4, imagem 2 %32
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-SZ120P Keyboard Replacement: passo 5, imagem 2 %32
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley Brooks
Membro desde: 04/09/10
312 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 5,604
