Ir para o conteúdo principal
Sony Vaio VGN-SZ120P Hard Drive Replacement
Ashley Brooks
Ashley Brooks e 10 outros colaboradores
Última atualização em December 11, 2022
Nenhuma estimativa
Moderado
Faltando Passos
Precisa de melhores imagens
Introdução
Ir para o passo 1
If you have not fixed your problem through our Troubleshooting Guide, then you may have to replace your Hard Drive.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
NOTICE
Make sure your replacement hard drive is a serial ATA hard drive (SATA). Any other hard drive will be incompatable.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Sony Vaio VGN-SZ120P Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 2, imagem 1 %32
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Hard Drive Replacement, Keyboard: passo 3, imagem 1 %32
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 4, imagem 1 %32 Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 4, imagem 2 %32
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 5, imagem 2 %32
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Hard Drive Replacement, Mouse Assembly: passo 6, imagem 1 %32
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 7, imagem 1 %32 Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 7, imagem 2 %32
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio VGN-SZ120P Hard Drive Replacement, Hard Drive: passo 8, imagem 1 %32
    • This is where your hard drive would be located. The replacement must be a Serial ATA(SATA) hard drive
    • Remove the four hard drive securing screws.
Conclusão
20 outras pessoas executaram este guia.
Ashley Brooks
Membro desde: 04/09/10
312 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
3 comentários
simple and perfect in every detail
francesco - Responder
como le cambio la pantalla a esta lap
Armand San - Responder
como le puedo cambiar el monitor a este modelo
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 43
Ao todo: 40,400
