Ir para o conteúdo principal
Sony ICFC1T  Battery Replacement
Anna Graetz
Anna Graetz e 4 outros colaboradores
Última atualização em January 9, 2020
2 - 5 minutos
Fácil
Introdução
Ir para o passo 1
This guide will give step by step instructions on how to replace your battery.
  1. Sony ICFC1T  Battery Replacement, Battery: passo 1, imagem 1 %32 Sony ICFC1T  Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the battery compartment from the underside of the device.
    • With your thumb and index finger, pinch the tab and pull gently until the compartment is released.
    • Always ensure that the device is unplugged before tampering with it to ensure there is no risk of electrical shock.
  2. Sony ICFC1T  Battery Replacement: passo 2, imagem 1 %32
    • Take out old battery by pressing from the side marked "PUSH" on the compartment, and replace with a new battery, positive side up.
    this makes no sense to me. what do i push????
    Janice Kochanski - Responder
    Battery compartment price
    Jerry Sheldon - Responder
    How much does the battery compartment cost
    We need the battery compartment adapter that holds the batterys, we lost ours
  3. Sony ICFC1T  Battery Replacement: passo 3, imagem 1 %32
    • Replace the battery compartment into the bottom of the device.
    • Reset the time of the clock.
    • Plug your clock back in as to not rely on the back up battery.
    Press radio button after install to remove low battery indicator light
    Dave Thomas - Responder
Conclusão
3 outras pessoas executaram este guia.
9Comentários do guia
Thank you so much for creating this. :)
LadyLion - Responder
step 2--I can't get the battery out of the compartment. Am I not pushing hard enough? Should I take a screw driver to pry it out? I'm afraid of breaking the compartment since it's only plastic.
Iris - Responder
The battery does not prevent the display/clock from switching off when I unplug the cord. Is the purpose of the battery not supposed to be to retain power even when unplugged? I have already put in a replacement one, presuming the one that came with it to be faulty. How do I get this to work?
Is the original Sony one meant to charge up or something? Please help as it doesn’t seem right if back up battery function does not do it’s job.
KIRSTY MCNICOL - Responder
The back up battery doesn’t seem to do it’s job. Unit switches off when unplugged. Is it the case that the original Sony battery charges? I assumed ut to be flat, replaced the battery but this doesn’t retain the power either
Is my clock faulty? How to engage the back-up battery?
@kirstyonline Kirsty, as the battery description says, it is only backup. So not for full device powering, but only to back-up time status while mains power is down. Unfortunately, this device is only capable of running from mains.
Radoslav Gulik - Responder
I cannot even open the battery compartment. What am I doing wrong. Its 15 years old I dont think it's ever been opened
robert poder - Responder
I just put a new battery into this unit but the no battery light on the face of the clock will not turn off. I did reset the time as instructed and pull the electrical cord out of the wall and re-plugged in to reset everything but the brand new battery out of a package now installed still gives me a no battery signal on the face of the clock.
gumley - Responder
Do you have a battery compartment for sale? I lost it. I can’t install a backup battery.
Miles Away - Responder
My ICF-C1T came without a unit to hold the battery or the cover ? Is there a reason it did not come with it? Is there a way of me getting one? I thought i read somewhere that the battery was built in and that is why the area for the battery was left empty and uncovered. If I do need a backup battery how do I get one?
elihu baer - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 33
Últimos 30 dias: 145
Ao todo: 16,564
