Ir para o conteúdo principal
Sony Cyber-shot DSC-H300 Screen Replacement
Zachary Meyer
Zachary Meyer e 5 outros colaboradores
Última atualização em May 1, 2024
5 minutos
Muito fácil
Introdução
Ir para o passo 1
This guide will teach you how to take off the screen on the Sony Cyber-shot DSC-H300.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Exibir mais…
  1. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 1, imagem 2 %32
    • Remove the four 6mm Phillips #00 screws.
  2. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 2, imagem 1 %32 Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 2, imagem 2 %32
    • Remove the two 6mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
    you need to remove one more screw inside the battery cover, you will see it once you open the battery cover.
    Belzebuth - Responder
  3. Sony Cyber-shot DSC-H300 Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-H300 Screen Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-H300 Screen Replacement: passo 3, imagem 3 %32
    • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
    • Be careful not to damage the three plastic clips securing the top edge of the rear cover.
  4. Sony Cyber-shot DSC-H300 Screen Replacement, Screen: passo 4, imagem 1 %32
    • Remove the two 6 mm Phillips #00 screws securing the left side of the metal frame.
    • Gently pull the metal frame away from the screen.
    • Lift the screen with the spudger and flip it to the right.
  5. Sony Cyber-shot DSC-H300 Screen Replacement: passo 5, imagem 1 %32
    • Remove the four 6mm Phillips #00 black screws.
    • Lift the metal plate away from the board.
  6. Sony Cyber-shot DSC-H300 Screen Replacement: passo 6, imagem 1 %32
    • Disconnect the LCD cable.
Conclusão
3 outras pessoas executaram este guia.
Zachary Meyer
Membro desde: 02/14/18
479 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G6, Nance Spring 2018 Membro de USF Tampa, Team S1-G6, Nance Spring 2018
USFT-NANCE-S18S1G6
3 Membros
Autoria de 10 guias
1Comentário do guia
where can i find the rear screen for sony dsc-h300
Michael Ramos - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 48
Ao todo: 2,258
