Sony Cyber-shot DSC-H300 Screen Replacement
Introdução
Ir para o passo 1This guide will teach you how to take off the screen on the Sony Cyber-shot DSC-H300.
O que você precisa
Remove the two 6mm Phillips #00 screws.
Remove the two 3mm Phillips #00 screws.
Remove the two 6 mm Phillips #00 screws securing the left side of the metal frame.
Gently pull the metal frame away from the screen.
Lift the screen with the spudger and flip it to the right.
3 outras pessoas executaram este guia.
