Ir para o conteúdo principal
Screen Replacement For Samsung Note 20 Ultra
Mark D Schlossman
Mark D Schlossman e 6 outros colaboradores
Última atualização em 22 de fev de 2025
3 horas
Muito difícil
Atreva-se a Reparar
Guia colaborativo
Introdução
Ir para o passo 1
I repaired a couple of screen replacements for the Samsung Note 20
I did one that needed a back glass and one that did not.
Created a custom back glass to troll my older brother for not having a case on a brand new phone. The replacement screens had not even been created yet until now we waited for 3 weeks!
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. Screen Replacement For Samsung Note 20 Ultra, Identify the problem: passo 1, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Identify the problem: passo 1, imagem 2 %32
    • On this Note 20 the OLED is clearly broken and has a crack on the side.
    • The back has no damage to it so apply heat.
    • Apply Heat to back glass
    • I do not have a picture of my heating process I hope you have a heat gun I use a crock pot with rubber in it.
  2. Screen Replacement For Samsung Note 20 Ultra, Prep for back glass removal: passo 2, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Prep for back glass removal: passo 2, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra, Prep for back glass removal: passo 2, imagem 3 %32
    • Be sure the back glass is too hot to touch!!
    • I prep my ifixit splicer with 99% alcohol to help losen adhesive.
    • Start from the bottom straight up and down push tool in until you hit the frame you will hear a sound
    • Slide tool at angle stop at the curve
  3. Screen Replacement For Samsung Note 20 Ultra, Back Glass Removal: passo 3, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Back Glass Removal: passo 3, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra, Back Glass Removal: passo 3, imagem 3 %32
    • After loosening the bottom pull tool out.
    • Heat is Applied
    • Now pry with your fingers and pull up with suction cup.
    • While sticking splicer on curved edge side slowly working wiggling down the curve edge
    • Lift and wiggle the back glass off
  4. Screen Replacement For Samsung Note 20 Ultra, Remove Sim/Stylus: passo 4, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Remove Sim/Stylus: passo 4, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra, Remove Sim/Stylus: passo 4, imagem 3 %32
    • We did it no cracks! High Five Youself
    • Remove Sim Card
    • Remove stylus
  5. Screen Replacement For Samsung Note 20 Ultra, Wireless Charging Coil: passo 5, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Wireless Charging Coil: passo 5, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra, Wireless Charging Coil: passo 5, imagem 3 %32
    • Remove 6 PH000 Screws from the wireless charging pad covering the battery connection.
    • Disconnect wireless coil from connections with plastic spudger
    • Use spudger at top on the metal squeezing it under the top of the wireless charging pad bracket.
    • Lift and wiggle slowly the charging pad off while locating the battery connection
    • Battery Connection!!
  6. Screen Replacement For Samsung Note 20 Ultra, Disconnect Battery: passo 6, imagem 1 %32
    • Disconnect the battery with spudger!
  7. Screen Replacement For Samsung Note 20 Ultra, Ear Speaker Bracket: passo 7, imagem 1 %32
    • Remove 4 PH000 Screws to the ear speaker bracket.
    • Also disconnect this connection!
    • Please comment is this a proximity senor?
    I had 2 of these screws break off as they were way over tightened. Wasn’t a big deal as i was parting out a live demo unit, but still….
    Stow - Responder
    I have another couple pictures that did not make it to the guide that the screws just disintegrated and stripped out where I dremmeled the brand new Note20 Ultra lol
    Mark D Schlossman - Responder
    I believe that is the connection for the Laser AF sensor and flashlight. I think the earpiece speaker connection is right by the earpiece on the bottom of that bracket.
    Edson Barlow - Responder
  8. Screen Replacement For Samsung Note 20 Ultra, Mainboard: passo 8, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Mainboard: passo 8, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra, Mainboard: passo 8, imagem 3 %32
    • The battery should already be disconnected!
    • Use a spudger
    • Make sure its disconnected
    • Disconnect all yellow boxed connections!
    • Remove the 2 PH000 Screws holding the camera
    • Lift mainboard with spudger from ear speaker goin down using the frame as a leveler
    • With all the connection the board may snag on the connections be slow and observer feel for tension.
  9. Screen Replacement For Samsung Note 20 Ultra, Front Camera: passo 9, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Front Camera: passo 9, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra, Front Camera: passo 9, imagem 3 %32
    • Front Camera do not break it is serialized to the phone! Can't be repaired if is broken!
    • Front Camera Location
    • Use heat or 99% alcohol to get it removed
    • Use straight edge blade at bottom of camera to break it loose. You can actually pull the glue/adhesive out it will come out in one chunk.
    • Lift camera out slowly
  10. Screen Replacement For Samsung Note 20 Ultra: passo 10, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 10, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra: passo 10, imagem 3 %32
    • Remove 5 PH000 Screws for the Loudspeaker bracket
    • Use spudger to lift out bracket
    • Disconnect flex cables
    • Remove 3 Black PH000 Screws to microphoned board and charger port
  11. Screen Replacement For Samsung Note 20 Ultra: passo 11, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 11, imagem 2 %32
    • Lift out Microphone board 1st
    • Then lift out charge port wiggling it loose
    • Good lift spot with point end of spudger at arrow location
    • Loosen Adhesive
  12. Screen Replacement For Samsung Note 20 Ultra, Small Parts: passo 12, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra, Small Parts: passo 12, imagem 2 %32
    • Remove 2 black PH000 Screws on top right lifting flex out.
    • Remove 2 PH000 Screws on Bottom right lift flex out.
    • Use heat it has adhesive holding it down.
    • The top right flex can disconnect from connection not sure 100% what all these parts do yet.
  13. Screen Replacement For Samsung Note 20 Ultra: passo 13, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 13, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra: passo 13, imagem 3 %32
    • Suction Cup, Green Plastic Spudger, and Alcohol to get it out.
    • Spray with alcohol start a little pry to get alcohol under battery
    • Lift with suction cup on battery
    • Bam its out not damaged
  14. Screen Replacement For Samsung Note 20 Ultra: passo 14, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 14, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra: passo 14, imagem 3 %32
    • Move back all small parts into new frame screen assembly
    • Vibator
    • Frame Flex Cables
    • Charge Port goes in 1st
    • Then microphone board goes on top of charge port. Connect the flex cables
    • 3 Black PH000 Screws
  15. Screen Replacement For Samsung Note 20 Ultra: passo 15, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 15, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra: passo 15, imagem 3 %32
    • Lay the main board down in new frame
    • Insert the front camera after laying the board down
    So when your laying it into the new frame, that the front part with the new glass and such? I'm just making sure I'm picturing this in my head correctly. I'm contemplating trying this but making sure I fully understand before I even think about attempting it. I guess I always thought when you opened the phone, the glass and front would come off and then you would have the parts and body of the phone in the back side frame. But here it is opposite where the back just comes off and the body is in the front frame. Correct? Im sorry, I probably sound so stupid. But I'm just double checking. Sorry this became so long and thank you for your time. :-)
    - Jamie
    Jamie Little - Responder
    Jamie, that’s correct. With the Galaxy phones the display and frame stay together and you take parts in and out. I’ve read descriptions of removing the digitizer (glass on front) but I wouldn’t try it. This way is pretty easy (once you get the back off)
    Stow - Responder
    Depends on which Samsung your working on but this is the best way if you do just screen you would still have to take apart whole device to ensure you don't short circuit anything you must unplug battery!
    Samsung A50 i think is a screen 1st if device is off or
  16. Screen Replacement For Samsung Note 20 Ultra: passo 16, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 16, imagem 2 %32
    • Lay out adhesive for under the battery
    • Connect the battery 1st then lay it on adhesive
    • Disconnect battery
    • Connect al loose flex cables to there connections
  17. Screen Replacement For Samsung Note 20 Ultra: passo 17, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 17, imagem 2 %32 Screen Replacement For Samsung Note 20 Ultra: passo 17, imagem 3 %32
    • Screw brackets down and wireless charge pad to test phone before putting it fully together
    • Apply adhesive to back of phone lay back glass back down
    • If you have to replace back glass you have to move microphone from old back glass rear camera lens to the new back glass.
  18. Screen Replacement For Samsung Note 20 Ultra: passo 18, imagem 1 %32 Screen Replacement For Samsung Note 20 Ultra: passo 18, imagem 2 %32
    • I use liquid adhesive to hold the back glass down
    • Clamp the back down for a couple hours
    What adhesive was used here?
    João Pedro Santos - Responder
    • We are done!
    • Did not have to replace back glass on this one :)
    • Replaced back glass on this one and added a fun twist of my face.
    • To remove back glass paint use acetone and blade to pull paint off.
Conclusão
During this repair on the black Note 20 Ultra I noticed the screen looked refurbished had issues with screws being stripped I did some serious work drilling into the phone. Which is not included in this guide.
Before I worked on the phone that had the stripping screw issue I already had worked on the phone which I made a video and had not issues with screws stripping the phone I did the picture guide was clearly refurbished straight talk phone.
15 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Mark D Schlossman
Membro desde: 09/25/19
6.777 Reputação
Autoria de 10 guias
8Comentários do guia
I did the repair and ran into issues with the REAR camera. I retraced all my hardware. its all connected. the selfie cam works. nothing got disconnected when I removed the mother board. i’ve tried to reset app cache
help plz
Abe Arslan - Responder
Do you have all the screws back in with the speakers and wireless charger coil on the phone?
Stow -
Rear camera hmm did you try repeating the connection did the cameras work before repair?
Mark D Schlossman -
Thanks for the effort here with the guide. Unless I am missing something (lol) where is the part of the screen replacement (by screen = the display screen, right?) I see the back replacement here. You do mention the OLED screen being broken at the beginning but the guide is for the back replacement, right? (not as title suggests ‘screen replacement) Sorry maybe am wrong here.
s ner - Responder
He transfered anything from the original phone to the new sreen/frame assembly.
Daniele Carminati -
Thanks Daniele - this had me confused “I repaired a couple of screen replacements”…and the sentence after that. Ok, so he took the back, board, battery etc from the one with the broken screen and mated it with a new screen. So one has to assume that somewhere in step 16 is the connection with the screen flex cable. Looking to see if just the screen is cracked, does the whole disassembly need to be done? (starting from the back working way to the front)? (think it is lol but hoping asking, as videos I have seen address broken screen (not just glass cracks) replacements-maybe the glass and the digitizer are fused?) thanks
s ner - Responder
In step 14 he starts to speak about the new frame (that include the new OLED panel and digitizer). Replacing only the glass is a bit difficult and you may broke the OLED too if you are not extra careful. You have to do the same that hr did for the back glass (better if you use an opening pick and you heat the side you are working on before you insert the pick, for each side, and you do not insirte the pick more than 1 or 2 mm). If you manage to do that, you can save a lot of money, else you have to buy a new oled too. So, i will suggest you to try to remove the glass without broking anyting, then try to turn the phone on to see if you broke thee oled. Finally, you decide what to buy based on what’s broken.
Daniele Carminati -
Highly recommend not doing the screen repair without frame assembly but you can do it just have high chance of screen falling off, or cracking oled when claping it down
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 75
Últimos 30 dias: 348
Ao todo: 25,613
