Samsung Galaxy Gear Band Replacement
Introdução
Ir para o passo 1To replace the watch band on your device, you will need to remove the band. This is demonstrated by the following steps. Removing the band also assists in removing the camera from the device.
O que você precisa
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
Grip the body of the watch and pull the band upward.
The adjacent band is not secured with screws. It is just friction fitted. I used a flat head screwdriver to loosen it and then had to use pliers to carefully lift it up out of the housing.
13 outras pessoas executaram este guia.
8 comentários
I have the non camera band (the one with holes )to be changed only. .... but I don't know where to buy it from and how to make sure that it will be the right one for this model SM- v700
Naji
Is there a shop in London where I can have this Band changed and repaired by themselves ?
Naji
Absolutely brilliant instructions. Many thanks.
On mine two of the screws were T5 Torx and the other two were T6 Torx, so something to look for.
Please advise are you able to ship to Pakistan
when will the bands be in stock?
where can i get these bands?
