Ir para o conteúdo principal
Samsung Galaxy Gear Band Replacement
O que você precisa
  1. Samsung Galaxy Gear Band Replacement, Display Housing: passo 1, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Band Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Band Replacement: passo 3, imagem 1 %32 Samsung Galaxy Gear Band Replacement: passo 3, imagem 2 %32
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
    The screws Phillips are PH000 (triple Zero)
    harnelbe - Responder
  4. Samsung Galaxy Gear Band Replacement, Band: passo 4, imagem 1 %32
    • Loosen the camera ribbon so it will easily pass through the watch body.
  5. Samsung Galaxy Gear Band Replacement: passo 5, imagem 1 %32 Samsung Galaxy Gear Band Replacement: passo 5, imagem 2 %32
    • Grip the body of the watch and pull the band upward.
    • Do the same with the adjacent band, but there will be no camera ribbon to pass through the watch body.
    The adjacent band is not secured with screws. It is just friction fitted. I used a flat head screwdriver to loosen it and then had to use pliers to carefully lift it up out of the housing.
    Lewis Addison - Responder
Conclusão
13 outras pessoas executaram este guia.
Dalt Lasell
Membro desde: 04/12/16
543 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 1-9, Maness Spring 2016 Membro de Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Membros
Autoria de 7 guias
8Comentários do guia
I have the non camera band (the one with holes )to be changed only. .... but I don't know where to buy it from and how to make sure that it will be the right one for this model SM- v700
Naji
Naji Ajaleel Ibrahim - Responder
Is there a shop in London where I can have this Band changed and repaired by themselves ?
Naji
Absolutely brilliant instructions. Many thanks.
On mine two of the screws were T5 Torx and the other two were T6 Torx, so something to look for.
Roger Palmer - Responder
Please advise are you able to ship to Pakistan
Mehboob Mehmood - Responder
These are very helpful but could do with one more step and pic at the end - for how to swap out the embedded camera.
Dan Bloch - Responder
when will the bands be in stock?
Nick Animations - Responder
I have replace the band, but the speaker is not working, whats wrong?
Ng Anshem - Responder
where can i get these bands?
Pandeni Shuuya - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 18,738
