Ir para o conteúdo principal
Repairing Vizio Television  Cable Connection
Ricky
Ricky e 7 outros colaboradores
Última atualização em September 15, 2020
1 hora
Moderado
Fotos de ação
Precisa de mais images
Guia colaborativo
Melhor Introdução
Having problems with your cable connection? Has replacing the cable failed to fix the problem? You may have a broken connection in your motherboard. This guide will help you repair a broken connection from the cable to the motherboard.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: passo 1, imagem 1 %32
    • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
    • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
    I had a blank screen problem, watch how I fixed my TV https://www.youtube.com/watch?v=keBU2e2S...
    Gus Calabrese - Responder
  2. Repairing Vizio Television  Cable Connection: passo 2, imagem 1 %32 Repairing Vizio Television  Cable Connection: passo 2, imagem 2 %32 Repairing Vizio Television  Cable Connection: passo 2, imagem 3 %32
    • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
    • (2) Phillips screws hold down covers over your inputs.
    • Note this screw holds down both covers where they overlap.
    • The bottom cover will not move until the 2 small Phillips screws are removed.
  3. Repairing Vizio Television  Cable Connection: passo 3, imagem 1 %32 Repairing Vizio Television  Cable Connection: passo 3, imagem 2 %32
    • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
    • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
  4. Repairing Vizio Television  Cable Connection: passo 4, imagem 1 %32
    • You can then put it all back together once again in reverse order and enjoy some cable TV!
Conclusão
14 outras pessoas executaram este guia.
Ricky
Membro desde: 09/17/13
840 Reputação
Autoria de 3 guias
Equipe
TechTucson WeFixThat Membro de TechTucson WeFixThat
Community
2 Membros
Autoria de 4 guias
6 comentários
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - Responder
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - Responder
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - Responder
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - Responder
Where can i find the nearest Service center of Vizio here in the Philippines?
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 17,757
